Well, you folks are overdue for an update.
I've been doing body work lately. I got patch panels for the bottom of the cowl and doors as well as cab corners. I got the doors and cowl done and in primer but I had to pull the cowl off the frame to remove the cowl trim band. I need to paint under the new band before I install the band and I can't access the bolts that hold the band on if it is on the frame.
The bottom of the back of the cab is gone so I don't have a body line to follow until I get the doors back on.
Still a long case of having to do this before I can do that.
I got the crank and pistons in the block and I am waiting for the rest of the gaskets, lifters, push rods and such to finish getting the engine together.
I decided that I kinda like doing body work. I ran out of gas for my mig welder so that forced me to have to try out my new tig welder. I decided that I really suck at tig welding. Looks pretty easy on the YouTube videos. After muddling my way through the patch panels, I watched a video on the 10 most common problems with tig welding. I have all the mistakes down solid. I am getting pretty good at sharpening the tig electrode because I can't keep it out of the weld puddle.
I'm getting pretty good at the bondo work. Overall condition of the cab is way better than my original plan. Gonna make for a lot more work in the long run because now I have to do more work on the box to get it to match the cab. Maybe I can cheat and beat up the cab after I get it painted to make it look like the box instead of making the box look like the cab.
