lowbudget50
- Joined
- Sep 23, 2012
- Messages
- 6,141
Coming along nicely. I haven’t even started on mine yet but I’ve got to finish Leslie’s car first.
I knew if I did not jump on it now I would not get it done LOL
Lb, here's a trick I used on a tandem trailer that was twisted in a highway collision. Instead of moving the centre bolt, I moved the holes that the bolt heads fit into. Of course, my application was hidden more than yours so the inspectors didn't notice it. I went on to haul a lot of gravel in that trailer over the next few years, with my fix.
Food for thought.
just wondering why the twin leaf? wouldn't it be simpler with the stock A setup?
That center pin doesn`t look center in the spring pack,can you just turn it around to move the axle forward some?
Drilling and bolting the spring pack in a second spot will change the stresses that the springs see in between that area. You will be fixing leafs that are supposed to be free-floating. This could be negligible, could result in bending or shearing the bolts, or at the worst you could bend or break the springs. Since introducing another hole in the springs and bolting it at that point is also introducing potential points for fatigue cracking in a heat treated spring, it's anyone's guess if you'll get away lucky or have issues.
Honestly, I'd personally look at either extending the frame or finding a spring pack with a shorter length.
The points mentioned above are just my engineering brain pointing out potential issues, what you do with it is up to you.
I hear you sir. Still contemplating. I have re drilled springs on off rpad rigs with no issues, but thats different than a car we will be driving hard on the street.
Yeah, in an off-road rig it's unlikely that an innocent will die if something goes terribly wrong. A street car like this, not so. If this was something like a trailer where the axle was trailing, it would be a lot different but I wouldn't personally be comfortable with it in your application.
The problem with doing that is the mount is what holds the leaf spring down. The u-bolts bolt right to the mount. So I cannot re-center the whole it is not long enough. And if that's the case why not just re drill it. I think I'm going to call our local spring shop and see if they can't make me a new top leaf. Not ideal but it'll work best. Then I won't have to stretch the frameI'd just redrill the mount if it's long enough. The locating pin doesn't have to be in the center of the mount, it's just to keep the mount from walking on the spring. Look at an AD series truck, people redrill the mount on them all the time to center the axle in the fender.
Wait, fenders? Hot rods don't need no stinkin' fenders ![ddd[ddd[ddd
Are shorter springs not an option?
