DJ3100
Re: GM Seville 79-85 rear calipers
I wish I had known all this stuff before I purchased my disc brake conversion, so I thought I would offer up what I found.
Gm and all the suppliers state the the parking brake must be applied every time the car is parked. This isn't for safety, it is to keep the calipers adjusted. If the parking brake is not used regularly the calipers get out of adjustment and there are no brakes!
Getting the parking brake adjusted properly when they are installed is critical. Some instructions say you may have to repeat the process up to 25 times to get the proper adjustment. Some people can never get them adjusted; give up and buy the non-parking brake version. Others say they have no problem. If you Google the calipers you'll see both opinions.
Those that got the calipers from a salvage yard report that the parking brake is usually frozen. That's because once they get moisture in them, they corrode and seize. Almost all suppliers say you need to change the brake fluid once per year. It seems that time is the factor for the corrosion not usage.
I got mine from Speedway, p.n. 901-31046, but CPP, MP, TMS and most other suppliers offer the same calipers for their rear disc conversions. It is interesting that the suppliers have different instructions for adjusting them. Speedway instructions also indicate they are difficult to bleed; they have a specific method for bleeding them.
Here's a link to a thread that shows how they work:
http://classicbroncos.com/reardiscs.shtml
I found that CPP had a really good brake troubleshooting chart and good instructions on these calipers. Here's a link:
http://www.classicperform.com/TechBook/BrakeTroubleshoot.htm
MP also has good instructions:
http://www.mpbrakes.com/docs/orig-guides/DB1791BR-INSTALLATION%20INSTRUCTIONS.pdf
Many people say they are happy with these calipers. I'm not badmouthing them, just pointing out that they can be difficult to install, require regular PB application, and frequent fluid changes.
The photo shows the ones this post is about.
