phil cottingham
I have a rear end from an 85 el camino that I plan to use in my build. It has 4arms connected to the frame. Is there any reason I can't use these mounting points on the rear housing and there same angles for mounting to my new frame? I plan to use the el camino coil springs as well. The frame will be built to make these things line up. Also if can use this 4 arm system would a panhard bar be necessary? Thanks for the help so for. I'm just getting everything together right now. I plan to start a build thread later if I can master the picture thing. Phil
