I have a bunch of 2x3x3/16 thick steel tube, enough to build my frame, but am wondering if I should set it aside and use 2x4 instead. What do you guys recommend? The build will be a relatively short wheelbase (106" or so) typical Z'd frame design, inline 6 cylinder engine/auto trans, transverse spring-over-beam front suspension, 46 Ford bobber truck with a shortened bed. Should I stop worrying and just use the 2x3? Maybe reinforce the area under the cab with a 2nd length of 2x3? What did you use? Thanks in advance.
