Neto
Has anyone here built a reverse ("sling shot"?) trike w/ a shaft drive running to the rear wheel? If you don't use a motorcycle drive line (like if you want to use an auto engine), and want to have a drive shaft running from a front engine arrangement, could a person use a ring & pinion gear to build a single wheel drive system? I was thinking that the ring gear could be mounted directly to a hub that would be splined for a shortened stub axle. The axle could run through the hub and run in a bearing in the outside differential cap if that would be helpful. Could something like that be built out of steel, or would it need to be cast?
I know that it would be easier to use a front engine FWD drive line out of a small car, and drive the two front wheels, but then you can't do anything special with the front end, like a dropped axle set out front suicide style, or quarter ellipticals, etc., to give it more of a ratrod/hotrod look.
