Dr Crankenstein
he left those holes undrilled because he wasn't sure what sender I would pick up.
I see.
Now you have me looking for a bit/tap combination. [cl
Your radiator must be smaller than mine. I wanted to mount mine under the rail but the BB Walker only had 3/8" clearance on both sides so I wound up mounting it to the top... oh well!
I see.
I was a bit upset when you put the RPU on the shelf. It is my favorite build coming out of your shop. Sure glad you are finishing it.
If you use http://www.ratrodsrule.com instead of the https:// address your multi-quote and emoticons should work again. Many of us have been having this problem.
Thanks, 05, it worked !!!!!
I use Firefox & have never had that problem!
Toad
Progress is Good [P[P[P[P
