David, I actually thought of somehow getting a Ford script pressed into the center of it but couldn't figure a way to do it. I may just get some pinstriping there or maybe "Ford" lettered on it.
I cleaned up the lenses in the license lights the other night, turns out they were just dirty, so some Dawn got them like new, and then Dan buffed the stainless housings for me and those came out nice. Now I just have to drill two 1.25 holes in the tailgate for the prongs to slip into and they will be mounted.
Last night I worked on getting the final panel made for the bed, this is the front of the bed. It is virtually a mirror image of the tailgate, except the bead doesn't continue onto the lower portion because it will be below the floor and won't show.
Here is the final panel in place, those notches are for the frame kickup and driveshaft clearance:
And the side view and looking forward into the bed.
My next step will be making a framework inside the bed to give it some stiffness and to support the floor, which I still have to make. I also have to make some crossbraces and stake pockets, and to drill holes for the button head bolts that will hold the bed together.
It will probably get wheeled outside tomorrow so I can look at it in the daylight from far away to see how high the bed should go.
