I stopped working on my rpu until we got Dan's car done, I didn't want anything to get in the way of getting his back on the road. But now that we have his running good again it was time to get back on mine.
The front suspension is pretty typical, just a 34 Ford undropped axle, a suicide spring, and split wishbones. But for the back we needed something different because I want the bed to be very short which made it necessary to come up with a suspension system that would work well but not take up much room. What we came up with is a triangulated 3 bar system with coilovers.
The one we are using came from a company called Suicide Doors and it is used on bagged s10 pickups and some prostreet cars. Essentially, it has two lower bars mounted parallel with the frame and a wishbone shaped top bar that acts as an axle locator and panhard bar all in one. Because of it's design the axle can not move from side to side. We had to shorten the bottom two bars and the wishbone because I wanted the slicks to be almost up against the body.
Tonight we wrapped up welding all the brackets on and the car is now a roller. [cl It will settle down another inch probably, but I have a lot of adjustment in the coilovers so I can set the stance wherever it looks right when the car is all together.
Here are some pictures from tonight. Now we just have to move the front radius rod mounts down a little lower for some more caster and to look better. After that we will mount the 56 Ford pickup steering box and figure out the front shock mounts. My goal is to have it done in time for the Billetproof Drags in October.
