donsrods
Ok, here are some pictures from tonight. The body, over the past few weeks, has gotten a couple of coats of Epoxy primer, and after that was scuffed we applied body filler (about 20 times ) sanded most of that off, and then applied a couple of coats of high build epoxy primer.
Most of that got sanded off too, and today we put on a couple of heavy coats of high build primer that we will let cure and then block sand a lot of that off. I am not shooting for a show car here, just a driver, and I am going to eventually spray it red and then black over that, and then scuff through a few spots to expose the red, as if the sun and time has aged the finish somewhat.
Let me see if I remember how to download pictures. The gray is the high build and the black is the first few coats of epoxy primer.
