ok guys ..37 ford with 302 5sp,,stock front end with gas shocks from speedway..ride is ruff,,pulled 1 leaf out lubed everthing up good,,with out shocks hooked up ,I can bounce the front nice , bolt them down its tight,,i put lowering shackles from socal on front spring dropped it 2 inchs put smaller bump stops on it.. it hits the stops..with the stiff shocks. sooo do I put the stock shackles back on lift the front back up that will give me more room for the bump stops, put softer shocks on and put a drop axle in it ? or give up an go mustang cross member an start over? wanted to keep the old skool frontend,,,but ride is crappie..what im I missing if I go with mustang cross member will all the parts from 87 GT front end bolt on ? I have the hole k frame out of the parts car, want to get the ride right before winter tear down changed out rear springs that's good now ..but got to get some kind of ride out of the front ..any help would be BIG!! thanks vicne
