Scratch Building a Coupe
More info on Coupe I had a 10 bolt top Ford 4 speed tranny in this car. It was my original Tasca Ford tranny 1964 Ford galaxie 390 cu incn which I drove for 25 years, This 4 speed is a special close ratio Ford 4 speed from Ford in 1964 option. I have to get in the shop and do some work ill post more later tonight see yah all.
    107.1 KB
    103.4 KB
    101.9 KB
Photos keep comming
    110.2 KB
    94.1 KB
    123.7 KB
    118.6 KB
Photos of the Mustang 2 front brake calipers, I like to rebuild everything if I can safves lots of money. but these gems the pistons would not budge so I did what i have done in the past. I drilled a hole in the back of the caliper inline with the piston and drove the piston out with a hradened 5/15 bolt. Then i threaded the hole with a 5/8 by fine thread bolt and use some sealant on the threads. Most people would just buy new, but thats why I have more cash for Mig gas, welding rods, steel and the list goes on. you will see a lot of these money savers as I go along here. I have more time than money if it dont work out ill do something else.
    94 KB
    81.8 KB
    37.8 KB
    77 KB
Photos.. everywhere
    46.1 KB
    91.4 KB
    111.2 KB
    118.7 KB
Photos..
    122.2 KB
    123.4 KB
    134.1 KB
    99.2 KB
Photos..
    110.9 KB
    139.3 KB
    104.6 KB
    139.5 KB
Scratch building a Coupe
Photos..
    103.7 KB
    116 KB
    101.8 KB
    92.6 KB
Cratch Building a Coupe
Photos..
    103.2 KB
    103.2 KB
    91.5 KB
    82 KB
Photos.. These photos are the start of my door hinges made from scraps lying around on the floor.
    78.1 KB
    90.7 KB
    106.1 KB
    68.5 KB
Photos..
    102 KB
    92.4 KB
    89.9 KB
    95.3 KB
Photos.. door hinges
    90.3 KB
    85.5 KB
    93.4 KB
    103.3 KB
Photos..
    116.1 KB
    108.2 KB
    114.7 KB
    123.9 KB
Photos..
    119.1 KB
    76.4 KB
    88.5 KB
    96.7 KB
Photos..
    109.4 KB
    91.3 KB
    112.3 KB
    104.5 KB
Photos..
    113.4 KB
    104.3 KB
    85.2 KB
    79.6 KB
Photos..
    95.9 KB
    140.5 KB
    102.5 KB
    101.2 KB
Photos are the other choices I had for engines in this Build. We decided (my brother in law) the 302 Cobra engine will go in the Mekur with a C4. And the other engine is a 1948 Ford Flathead engine that i decided not to use because of the costs. I have the Mercury Flat head engine all apart so I will eventually rebuild that one. The 302 is to hot for the street it has Highly Modified 1969 351 windsor heads with shortened 390 valves in them. I built these to compete with the Chev 2.02 valve heads. But mine were promptly outlawed by the track promoters. hmm dont stink up the program I was told. Anyway Ill take them off as well as the cam etc and put on some street heads with a milder cam.
    89 KB
    108 KB
    172.7 KB
    125.3 KB
Photos..Look at the rust on this Mustang 2 front suspension, A little cleaning and some rust converter made it look lots nicer...
    128 KB
    119.2 KB
    118.6 KB
    87.8 KB
