All day cutting, prying. bending, grinding, relocating, phew glad its all done and changed. The seats fit now but with no wiggle room what so ever. I had to take off the sliders from the seats they made them to high. There is no room to slide the seats they are all the way back as far as they can go. The passengers seat will have more leg room than the driver because of the steering wheel and pedals etc. I had to change the seat belt brackets and cut away 8 inches rearward of some tubing starting at the doors and going back a ways. Then I had to change the position of the middle seat belt brackets and catches for both seat belts. No room to spare the seats will fit now and I will keep them in a box until I finish all the other grinding , cutting, painting etc inside the seating areas. had to even modify the shifter with a bend to the right and then a bend back up vertical. The shifter interfered with the corner of the drivers seat when in 1st gear and reverse. The bends made it better to shift now. I will still have to drill holes in the floor to mount the seats when i am ready, that will be one of the last things I do. I still have tons of work to do in the dash area and seating areas.
