Old Iron
Oh my that sounds nasty
[cl
Good things come in small packages. Good luck at the track. Do you have a procedure for checking out the handling of a new car?
Weather permitting I will be making the first runs with the car tomorrow. Hopefully all will go well. The plan is to take it easy and not break anything. Might not use the trans brake at all.
Have I ever mentioned how much I enjoy putting the diaper on this thing. NOT!!! But I'll be glad I did if this thing decides to put out a rod or two.
Well done. [cl
Why does it shift to high on the brake? Electrical issue? "Bumping" the shifter through inertia and/or incidental contact? Reverse pattern?
Whatever the case, I can imagine 60' times in the 1.20's when you figger it out...
