Dirtyrat
Got Fins?
I'm using some mustang rear shocks, which are gas charged units.
At ride height (suspension loaded) where in the range of travel of the shock do you guys usually setup your shock length? [S
Also one other question, do you guys typically use steel straps to retain the coil springs in the event that the suspension is unloaded? I've seen them on the front end of different vans, etc..
I'm estimating a minimum of 2" of rear suspension preload from body weight, and the tank.
And then about 3" of suspension travel to set the axle snubbers (about 4" of body to tire clearance, down to 1" at the snubber)
Thanks for any input guys!
