olcarguy
Some of you are just getting started with metal work on your vehicles. This is a trick I learned from an older German tin basher. It is what he learned on when he did his apprenticeship in the old country. Nothing more than a simple piece of angle iron cut in the middle to form a circle, held in a vise with the small size. I use two vices for the 48"er one at each end. Simply clamp the metal you want to bend and strike lightly with a hammer, gradually from one end to the other till you reach the angle desired. Hope this helps....
