Bamamav
I, er, OK, don't know what to think. Looks like it would have been easier to just find a truck cab to start with, but I guess you use what ya got.[S
I'm definitely interested to see your progress as it comes along. Interesting machine. I've often thought of the "VW as a cab" plan, simply 'cause bugs seem to still be out there and somewhat cheap.
Keep us posted, we love pics. [P
Regards,
Shea
hey guy looks like fun.....I too have a VW bug in my shop its on the back burner for now while i build my truck. just thought I might add that on your frame where you made cuts and modifications it best to box those areas and fish plate the outside for added safety. just my 2 cents worth. have fun with your build ....Doug
easy. . . . . nobody here is doing it the easier way. everybody on this forum is building a car. there isn't anything easy about that. some of us just pick our battles differently. I like vw's and I wanted a truck, a duallie truck, with a blown small block. so I'm building just that. a dualie vw truck with a sbc. a lot of guys bore holes through their frame rails for effect and some small amount of structural support. it's not the easy way. but it looks cool.
I did quite a bit of research before I decided how to make the body lines go all the way around. turns out bug door skins and 54 chevy truck cab corners do the trick. the rest was just a lot of eyeball, measuring tape and patience. I will fully agree with you though. starting with a full cab would be easiest. but I was clearly dropped as a child. I keep my remaining bit of sanity by bouncing between the motor, frame and body.
Very cool. I like different. Are you leaving it a dually? What kind of grill shell do you use on a vw bug-truck?
