Yeah, it's still fun! I should have made that crossmember removable on the last change when I dropped the I6 and 727. Duh! But yessir, ya live and learn. I didn't have the cab on it then and wasn't thinking ahead enough. Now I don't have enough room without pulling motor and tranny together.
And Sarge, I didn't notice any freewheel and then drop back into gear. Usually it pulls off and goes beyond where it would normally shift out of low and just slips. Nail it, and it shifts hard all the way thru. At one instance today, it shifted really nice up to 3rd and I nailed it to drop it down, which it did, then shifted on out but as the rpms revved up I could tell it was slipping under throttle in 3rd. Another thing that has happened two days in a row is at the same gas station. Their property around the station is lower ground than the roadway going by. Both of their driveways are fairly steep ramps to the level of the road. Both times I've pulled away from there, it was necessary to stop on the slant and wait for traffic. Pulling away from there on both occasions It wouldn't shift. That kinda reminds me of a low fluid issue but that's the first thing I did was pull over to level ground and check the fluid....level was right.[S
