Hi,
This is my first try at this forum stuff. I have started a 1936 Plymouth sedan build. I have looked at all threads about this subject but still have some questions. I have decided to use the R & P attached to my axle. It's a tube with a four inch drop. I know the RP needs to be level and centered. Do the tie
rod arms need to come level out from the body of the RP? I'm using a 2003 Kia Rio power RP hooked to a chev PU tilt steering column that has the slip section in it. I have a 454 I'm using and I want to use it's steering pump. Do R & Ps work with any pump? This looks so simple am I missing anything?
Thanks
Thanks
