Onequick26
Puts Nitro on his Cheerios
As some of you know im useing a speedway front end with the chevy spindles.Ok here's my problem,There is a spacer that goes on the spindle before the rotor,when i put it all together and adjusted the castle nut is too far out to use a cotter pin and with out the spacer the rotor won't adjust the way it should(it's too lose)so any one had this problem.
Don,
You said your son used one on his car, did he have the same problem ?
Don,
