That's an easy way to get pics on. If not photo bucket, there are a number of other online photo sharing sites. I personally have a google blogger blog site that I post my pics to first and then copy the urls. Any one of the sites should be equally easy.
As for bagging the front, if you run it static to start, you just need the bags, fab some brackets for them, a set of shocks to setup outboard, and fab brackets for the shocks. If you go with cheaper bags, you can get a set for around $100 US. If you get high end bags, you'll spend about $200 US. A few fittings are also needed but they are cheap. If you are interested, there are a batch of pics in my build thread (signature line) and I would be happy to answer questions about how I did mine and about variations that I came across during my research while prepping to set mine up.
Look on ebay for drop spindles. I would guess that some of the places on there will ship through ebay international shipping.
A totally free way to get about an inch lower is to do a ball joint flip. To do it, you literally just unbolt the ball joints from the upper and lower bottoms of the control arms and re-bolt them on the tops. For the lower one, you have to pull the strut rod nut plate off and flip it over as well so that the long arm of the lower ball joint can sit under the bar between the 2 nuts. If you want more info, if can take some pics or try to find a link to the write-up that found on doing it.
One more thing to throw out there is that a Ford 8.8 inch rear end out of an Explorer will bolt straight in. It will drop right onto the pins in the springs! I couldn't believe it before I saw it for myself. You have to pound the crap out of the corner of the gas tank for clearance but otherwise it's a simple drop in. You can get disks brakes and trakloc and a much stronger axle all in one go.
Finally, the forum
www.toyotaminis.com has a lot of good info on these trucks.
Sorry for such a long winded post!!!!!
