bob w
The 377 (400 block with 350 crank) in my Fiat has an interesting problem. When taking off at about quarter throttle There is a metal on metal loud ticking sound through first and second gear. It sounds like it is at engine speed. If I let off it stops. Doesn't do it at light throttle or full throttle.
I'm aware some mini starters come with the nose piece shimmed out. This starter has one shim. These are a flat, round shim, not the strip shims that go between the block and the starter.
Has anyone else had a problem like this?
