05snopro440
Hey guys, I have a forged so-cal axle and front end that I'm trying to assemble for mockup for my 28 Model A RPU.
Everything was new. The issue I'm having is the PS spindle is tight on the axle. I've filed and sanded to get it to fit better, and it initially works fine and the the surface of the spindle and axle gall together on the top side. The driver side is perfect with or without paint on it, and flops around easy. The passenger side is tight for some reason. Has anyone dealt with this that can recommend the best course of action and/or suggestions on the amount of clearance between the two that would be best as well as what level of finish would be best on both sides? I've attached a couple photos for reference. I bought new to make it easier on myself and I'm pulling my hair out. Hopefully someone can help.
This has only been assembled and put together on the bench, and did the pictured damage after 4-5 turn cycles after I initially had prepped both surfaces with 400 grit and cleaned them well. No brakes or steering installed, just the spindle. Everything is all new. Originally this side was really tight, I have sanding both sides of the top joint down with the DA and it's improving. Do I just keep doing that or am I missing something?
