Decided on a truck style exhaust stack and an air filter assembly I had laying around. Also considering reconstructing the front end with a simplified version of the dropped axle set up.
Update- Added a couple of extra rails into the chassis, installed a seat, accelerator and clutch pedal hooked up, and gear stick done. I welded a bolt to the top after these pics and put a screw on shift knob. The steering column will be modified once again with an extra uni joint in the mix to turn it up more vertically. I'm also building a transmission type tunnel through the centre and the chain will run though it to the back.
So the full size air cleaner on there looks pretty dang awesome I must say. I like the whole thing really, but I think I would run the exhaust out the back. Just looks a little out of place there in my opinion..... [P
