Thanks guys...
Thanks, coming from such a talented group of builders ( and that's no B.S.), the feed back is very much appreciated.
I was disappointed not to get the quick change back in time to install it before leaving again, but it just worked out that way.
Being a converted stock banjo, there were some things to machine and work out to assemble it right.
The Lime Works guys were actually excited to be working with such an "old, never touched, piece of hot rod history" (their words
), which is why I wanted to install it in the first place.
This is more or less a one off type of installation, though a lot of parts available now work.
When the banjo and cover went to the chromers, they pollished them, and some large pits appeared in the rear cover, so Lime Works crew had to fill the pits, then send it back for polishing and luckily there was no more pitting.
They got it back from the chromers the day before I left, so I just ran out of time....again. They still need to locate or make a bearing retainer for the pinion gear, that will fit this application. Photo is attached of the quick change, although I realize most of you have seen it before.
Once again, thanks.... '22
