Mike S.
Thank you Lucky, I hope you're right! My truck would have been done by now if I would stop changing my mind.
cant wait to see the frame sleeved out.. Get to welding...this part sucks..lookin forward to the updates[
Yeah, it's a pretty monotonous operation. I am glad that part is over and I only drilled 28 holes. Doing the entire frame must drive you guys nuts!
Mike, we use a plasma cutter too...shh lol dont tell anyone though, but i have been in your shoes man i used to not have one and had to do our first coupe all by drill press and hand hole saw.. It was hell cant wait to see the updates!
Making a template from 1/2" MDF by running the holesaw through it, clamping it to the rail and using it to guide the plasma works real quick too.
Don't have to drill any steel at all that way
I use 1/8" masonite. It's cheep, holds up to the heat, easy to cut and shape. Plus it is thin enough it doesn't kick the tip out. Nice work BTW.
Those are kool mike! Comin along great. RR
Cool. I only use 1/2" as with my particular plasma nozzle it gives me a couple mm of standoff. Helps the electrodes last longer
