Mike S.
Ok, so next was to tackle the doors. I had already cut the tops off to check the chop with the doors, roof pitch and so on. Before I cut them I used a flexible seamstress tape to check the actual width of the door frame including the contours. That measurement told me where to remove 6" and have both pieces line back up. I cut them again at the top to "stretch" them equally to the roof. Now, I've seen a few guys online that say they simply removed a vertical section and added it to the top to fill in the gap. I took a ton of measurements and couldn't get it to work so I went another route. The vertical portion of the frame matched the top of the frame closely but the body skin was way wider. So, I tapped the body skin off, reworked the frame a little, then sectioned the body skin to match the frame. Does that even make sense?! Anywho, the vertical portion of the frame lined up perfectly and the front of the door frame lined up pretty well requiring just a little contouring to blend the angles. The window opening now measures 8 1/4"!
