Ok ,last night I tried to fire up the beast on my shop floor. Everything went wrong. First off ,I guess I had it 180* out! because it back fired the second try. When I realized what the deal was , I rolled the motor over ,pulled the distributor, and set it at TDC . Only this time on the compression stroke. It fired and ran for 5 seconds. I looked down and saw a river of oil rolling under the oil pan. I immediately shut it down, to investigate. The oil filter separated at the seam , and blew off on the floor. I now have about 2 1/2 quarts of oil in the crank case. It took about 2 seconds to blow that much oil out. Dangit! Not sure if I had a defective oil filter , but it crowned the filter right around the seal. Almost like too much oil pressure. I primed the oil pump after installing it, and didn't encounter any issues with that. With a hand drill , I had about 35psi. I made sure that I had oil to all of the rockers. Gonna take that oil filter back to the parts house and load up on Lucas additive, and more oil. Dangit, I hope I don't have issues with it again tonight.
