Shea Laking
Well I mocked up the 283 and powerglide, built motor mounts and trans mount. Also bolted on a set of headders that were left over from a 3rd gen Camaro project that's long gone. With some tweekin I think they'll work. Will fab a crossover pipe into a Y pipe then run a single pipe to the back.
I made the trans crossmember low so there will be room for the exhaust pipe to go between the floor and crossmember. looks like I have enough room for distributor clearance and still have room for a radiator. I plan to use the Baja hood and build a homemade grill over the radiator. The wheel base is 114 inches in order to accomadate front mounted motor and stuff.
This thing's cool as heck! If you're only running one pipe, you've just gotta put one of those old-school "stinger pipes" dead centre out the back!
Can't wait to see more!
Regards,
Shea
