Rusty.Here is all the info.Get the seat you want to use in the truck.Bolt or screw the steering wheel you want to use onto a piece of dowl or anything that will fit through the hole in the floor until your comfortable.Then just use that measuement to order your column.Have at least 3 inches through the floor or fire wall if using cloumn shift.Or the selector will hit when its shifted.
