lazarat
- Joined
- Feb 7, 2018
- Messages
- 657
Because the Holley is now dumping fuel all over the Edelbrock manifold turning it orange. I had finally got this thing dialed in perfectly, float adjustments, mixture, even replaced bad manifold and spacer gaskets which were causing idle problems.
Now, it is leaking fuel out of the accel pump on the front bottom. Is this an easy fix or should I go for the Edelbrock carb which seems to get good reviews?
I will pull this thing for the last time to either repair or replace. Thoughts on either?
