the past couple days i have been back on the 57 retractable. lots of fun metal shaping lol
this is what the tail light surround mounting area looked like before, i forgot to snap a pic before i started
after cutting out all the bad areas to make room to work, i cut out some rings on the plasma table to match the back of the tail light housing, and tacked them to the body using the bezel as a guide
after the ring was tacked in, reinstalled the bezel and made a paper template to aid in layout of shrinks and stretchs and give me the basic size and shape of the material needed
after a good long while of shrinking, stretching, wheeling and hammering i have a pretty good looking patch. doesnt look like much but there is a ton going on in this little area, a tapered reverse compound curve
marked, and cut out for new patch to be butt welded in
after all the welding and grinding this is what i had, still needs some attention. but at this point there has been no hammer and dollie work done just welding and grinding
then moved on to the lower area
