V8 Bug Build..Now with working Photos!
Started on the rust repair at the bottom of the drivers door. Made up a template and transferred it to metal. Still rough, but getting there.
[/url]20160904_115242 by Ben Modified, on Flickr[/IMG]
[/url]20160904_125434 by Ben Modified, on Flickr[/IMG]
[/url]20160904_125321 by Ben Modified, on Flickr[/IMG]
http://www.BenModified.com
Cooling
If it cools and you like it, that's the right way. You can do lots with a stock bug hood. If you mess up cutting an opening for the radiator, just grab another and have at it.
Continued from above post.....Making the shape more square like the original
[/url]20160906_101151 by Ben Modified, on Flickr[/IMG]
[/url]20160906_101229 by Ben Modified, on Flickr[/IMG]
[/url]20160906_101331 by Ben Modified, on Flickr[/IMG]
New inner in place
[/url]20160906_112402 by Ben Modified, on Flickr[/IMG]
[/url]20160906_112444 by Ben Modified, on Flickr[/IMG]
Every thing welded in. Just need a skim coat of body filler on the outside and a couple of drain holes at the bottom
[/url]20160906_173834 by Ben Modified, on Flickr[/IMG]
[/url]20160906_173923 by Ben Modified, on Flickr[/IMG]
Rust repairs on both doors are complete. Re-installed them this morning
[/url]20160911_100332 by Ben Modified, on Flickr[/IMG]
Prior to removing the doors, I drilled a small hole thru the hinges, the body and the backing plates to make re-assembly and alignment easier. It worked very well, I was able to re-install the doors by myself with the help of a floor jack and a couple of drill bits. I tightened them down and they shut properly on the first try!
[/url]20160911_091623 by Ben Modified, on Flickr[/IMG]
[/url]20160911_120029 by Ben Modified, on Flickr[/IMG]
man what a cool build!
I saw a v8 gasser-style vw once in pics on the internet and have been wanting to build one ever since!!
keep up the good work-- and keep us updated!
[cl[cl[cl[cl
