donsrods
Good, looks like you are getting some results. One thing I would suggest is to buy one of those Mr Gasket radiator caps with the thermometer in the top. My dash gauge reads 20 degrees hotter than my Mr. G cap and also my infared gun. I installed the Mr G cap to find out what the actual temp is, and I find it more accurate than the dash gauge.
Also, Chevy engines seem to be fussy about where your sender is installed. When I had my 23 with a 350 I first installed the sender at the back of the intake, and it read a max temp of 120. I moved it to the thermostat area and it jumped up to 150. Then I went to a 192 degree thermostat and it went up to 170, which is still too cold for good efficiency. I started getting carbon on the valves because the gas wouldn't burn off all the way, and I had to pull the heads and clean the valves.
If you can get an infared gun try it and see what temps you get on various areas on the block. The hottest area seems to always be the water passage right at the front of the intake. Or, you could go to Advance Auto and buy a Mr Gasket cap for about $20 and see how that reads for you. You might be thinking you are running hot and really not be.
I used to like my cars to stay at 180, but am learning that 210 is not all that bad. My daily driver runs at 206-212 and I took it back to the dealer, thinking it was running hot, and they told me that is where it is designed to run. Live and learn.
