What would happen if I welded a stud on the base of my vise, then I could just clamp the piece in the vise and put the ground on the vise? Why won't this work?
Ah, I do the artsy myself, I know how it is. Do you have smooth jaws in the vice? A steel table works good with swivel pad vice grips. So are you welding TIG then? How is that working for you?
Ya TIG, a test in patients. I have good days and bad days but I know if I won't so lazy and did it more often it would be easier.
I do have plans in my head for a small steel work table (maybe tomorrow (ha))
Hope this picture shows well enough
the last shop I worked in had all the vises set up like that. I never crawled under to see how it was connected. I assumed they hooked the ground to one of the mounting bolts underneath the bench. it sure was nice to be able to clamp something in any vice in the shop and grab the torch and zip away on it.
