bruno
Crusty Rusty Old Rat Rodder!
Absolutely nothing.
I didn't know Porsche made a tractor, until now. [cl
In sunny California????![]()
I've pulled well pumps before too.
Like you said, not all that hard to do.
Did you determine what the reason was why it was hard to get moving?
Do y'all have to contend with cave ins much in the sandy earth?
As much sand that pumped out when the pump cranked up the one time, it might be sitting in sand. But that means I've got about 75' of sand packed in my well casing. When I get the air lift pump rigged, I'll run it until the sand is out. Down here, we have bedrock down deep but sand and clays above and below. They drill till they get below bedrock and casing is down that far. They don't slot the sides of the casing like they do in rocky terrain. Casing is solid and pumps are placed in the water column deep enough to get good water, but they run the drill pumps for quite a while to blow a pocket and pump the sand until the water clears. It might be a sand cave in underground and I'll just have to pump until it clears. Smarter fellers would have paid several thousand dollars to have pump guys come out. So far, I've got all new well and about 700 bucks shorter...Sounds kind of like it may have been stuck in sand at bottom of well shaft. How deep is the pump set and what is the static level of the water in shaft. You may be able to raise the pump a little to get it off the bottom.
