BigIrish
That is a good idea. I'll probably make use of something like that on the hood and maybe a panel in the back to access the gas tank. Everything else is going to be easy to reach since the car will be so simple.
OK I finally figured out a solution. Apparently they make a pop rivet that when finished looks just like an old school solid rivet. Used for reparing Airstreams, old truck cabs etc that were orig assembled using solid rivets. You have to buy a tool that shaves the head nicely after installation, but seems like it will look good when done. So this is what I plan on using:
http://www.vintagetrailersupply.com/Olympic_Rivets_p/vts-179.htm
Stay tuned!
When I just wanna go it fast....I just use my ESAB 650 Powercut Plasma.[P[
Ok now that I've got most of the sheetmetal done, I need to figure out what would be best to sand/scuff it with in order to give it a satin look. Shiny is fine, but I have a lot of fine scratches in it from sliding around while bending & cutting the metal. I'd like to hide those.
1000 grit? Scotch-brite?
