Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Tech Tips!
Tech Tips! Share your kool tech tip.
Old 02-23-2010, 11:56 PM
SideShow's Avatar
SideShow SideShow is offline
Lightbulb Speed Potential Calculator for Ring Gear and Pinion Changes
This calculator is designed to give the potential speed values of a vehicle, based on the RPM of the engine, the ring gear and pinion gear ratio, the final transmission gear ratio and the tire diameter, ground to top of tire as mounted.
The default values are for a typical V8 small block Chevrolet vehicle, however you may enter any value you wish. The default values yield a highway cruise speed of about 65 MPH. The higher the RGP ratio, the lower the top end speed but faster acceleration and more pulling power. The same is true of the transmission final gear ratio. The higher the engine RPM, the greater the potential speed at the cost of fuel, heat, friction and engine longevity. Although there is a point of diminishing returns, the larger the tire diameter, the higher the potential speed.
Try the Speed Potential Calculator for Ring Gear and Pinion Changes
I don't know where I'm goin' but I want to get there fast.
Old 02-24-2010, 07:47 AM
Gregster's Avatar
Gregster Gregster is offline
Good link , now stored in my favorites-- Thanks
I have a lust for rust
Current build link '36 Dodge Truck
RRR built link '30 MODEL A
Old 02-24-2010, 07:59 PM
Thanks for sharing that. Saved it.
Old 02-24-2010, 08:50 PM
DJ3100's Avatar
DJ3100 DJ3100 is offline
Me, too. thanks
Old 07-14-2016, 08:05 PM
SideShow's Avatar
Updated...
Old 07-14-2016, 08:49 PM
Well take a dump in a bucket! I just found out I don't have the rear gears I thought I had.... or my tach is WAY off.
Old 07-14-2016, 09:53 PM
I-R-POPS's Avatar
I-R-POPS I-R-POPS is offline
''Rusty Mopar Slacker''
Thanks for posting this. It's dead nuts on according to my GPS.
POPS
'47 DODGE SHOP TRUCK
48 DODGE Pilot House Rat
MIND OVER METAL
SO LITTLE MIND IT DON'T MATTER
Old 09-15-2017, 02:33 PM
SideShow's Avatar
Updated...
Old 09-15-2017, 05:29 PM
Right On
