1927 Chrysler build
I used a chop saw for the cuts just initially too a 1" pie cut out by the firewall. Then started with the pie cuts. just started with the frame leveled out had a brace of two welded across and just started bending lol.
Right now it's channeled 4" might go one more inch and cut the rot off the bottom. As for the front axle not to sure yet have a chevy one lying around that I think I'm going to start to make some brackets tonight to a set of homemade wishbones. That's the plan anyway lol
once again fresh thinking....what did u use to cut the relief cuts on the forward part of you frame to make the bend....i dunno a picture is worth a thousand words but what did you use for a blade and how the hell did you figure where to cut to get the swooping arch on that frame....did you have a frame table or did you wing it?....i just scored a model a pick up and have to build a frame there are just so many ways to skin that cat..are you doing a high boy or are you gonna do a slight channel? ..what are you using for bones?....what do you use to pin the bones to the axle?...im trying to avoid the speedway catalog as much as possible....sorry for all the questions ...but this is what it all about.....thanks im gonna be all over this build!!!
Nice build, keep up the good work and keep us posted. The body lines, firewall and frame are identical to my 1930 Chrysler sedan. I kinda like the different lines it has, especially on the cowl (that point). I glassed in a point at the bottom rear panel of mine to match it. The only thing that doesn't work for me is the fact that the body is wider than a Ford, and it makes the rear axle stick out (if you can) too wide. I had to tub mine. At first I wasn't crazy about it but the more I see it the more I'm likin it. Interesting build, again , keep us posted.
Ya the more I'm looking into it I'm thinking it's probly around a 30 sedan but still not a 100% lol
Time for some updates been a while
Start of my brackets
The Idea
Little further along
Little prettying up the front.
Had to move some of the old lines and start the top rail
Updates... slowly coming together.
Started floors have to roll some beads in it yet.
Now drip rail equipped.
Have most of the stuff I need in the back think I'll actually have a floor with usable space in the back :)
Start of the interior
Few more updates ..
Few more pictures..
Nice work on all that interior tin. You're going to have a one-of-a-kind hot rod when you're finished.[cl
Well started back on the toy got a little bit done this week.
Now just working on the cab getting it ready for primer. Bondo work is getting old though lol
Little update as it's been a while :)
