1930 Model A truck build
Kasselyn29
Jan 13, 2011
186
Found this cab from a friend and started to piece it together. Missing drivers door one will turn up some were.
A truck
Started working on a chassis, have a few ideas going to try.
A truck
Ladder bars showed up for rear suspension that was today's project. Front axle is not dropped but going to try to use it.
A truck
Thanks guys, can only post one picture at a time. Might be a slow moving project but you never know, the way winter is going right now I could be in the shop alot.
Looking good, can't wait to see more.
By the way you said you can only post one picture at a time. I also had that problem when I was using my iPhone to upload them. Once I started using my PC instead it worked fine.
-Chris
Looks like it's on it's way
Are those Chris Alston ladder bars ? I put a set on a customers car that look just like them.
Looks like a good solid cab for a starting point.
After seeing your build on the Mack, which was really sweet,
I'm sure this is going to be good.
What's the plan for this one?
A truck
The ladder bars are from jegs nothin fancy. There is no real plan, just have fun. Started to modify and install front ladder bar brackets, didn't think ahead enough now safety strap for hemi won't work. Wil come up with something different for that at some point.
Update
Small update working on front and rear suspension. Made front crossmember and front of frame. Trying to use front axle I already have so hope it's low enough.
Update
Rear suspension, should be able to start body mounts soon.
Update
Cab on frame
Put cab on frame still lots to do want to get it down on frame rails another inch or so. Starting to work on mocking up rear axle.
Rear axle brackets
I've found if you weld on a muffler clamp to your brackets it makes a good way to mock up this stuff.
Clamp
Ya it works on lots of stuff, and it is cheap. Here's the front.
