1941 chevy truck rat rod
got a motor, 472 cadillac $200.00 running!and a neat lookin tractor grill from blue eyed devil[cl thats about it been busy at work.
got the ladderbars made today, ill get some pics. brought the caddy engine home, gonna start triangulating the frame this weekend... ill get pics[P
got busy on the 41 today, took the cab off and took the frame to our shop in louisville,heres some pics.. cut the s-10 frame to make a backhalf for the 41. the origional frame has way too many pits for my comfort.[cl the frame slid into the other perfectly, had to go back about 14" and notch the frame so the front of the s-10 frame would taper to match the 41...
some more pics welding and prepping...picture three shows were i had to notch the frame to let it taper in. picture five is my handy little welding jig, helps ya get the right angle!!!
welded pics and goin to the house
also built the ladderbars friday heres some pics... project for next weekend!!![dr
few odd and inns i picked up...got the grill from blue eyed devil[cl CANT WAIT TO GET THE FRONT END UP IN THE AIR AND THAT 472 CADDY IN IT!!!
got these three weld supersingles on ebay 15x12 $199.00 thats less than one wheel new.
got the tires mounted, this build is moving slower than smoke off cows@#t!!!
started workin on mine again, been really busy at work(thats a good thing) got the front end off and im gonna use a 50 ford frontend, gonna make some brackets and do a buggy spring style front axle. picture 5 will kinda give an idea ill get some more pics as i go...
0
more pics
built the buggyspring frontend today[;) got a little more cleanup and drilling for hairpins.....[P
lookin good.
i dont want to rain on your paraid but, your rear tires. they have a very cool factor indeed, i have them on my quads. there to soft to run on the street and you risk putting your hard work into a ditch and or someones elses rear bumper. it would suck to do all that hard work to smash it for the cool factor.
lookin good.
just there for mock up, i learned not to buy new tires at the start of a build, they might be dryrotted before your done.... thanks for the headsup though.[P
hey on your front end , mainly the shackle area, you are going to find that the shackle is going to jit the upright you have made. Rule of thumb is that with no weight at all on your spring the shackles should be straight out from the spring eye so that when the weight of the vehicle is on it, they will be at a 45deg angle. As it is now when the weight comes down, the shackle will want to be straight down and then it will hit the upright. Might want to think about putting the outer shackle mount out on the bat wing plate you built. That will give you more width and let the shackle swing under without hitting anything. Just my $.02
