We've got snow I-R...
But with me and 3 dogs it's getting kinda yellow around here.
PVC well casing so we shouldn't have that problem.
I know you guys are probably getting tired of me messing with this front clip. (So am I)
Last pics of the fenders showed the filler pieces put in but we just eyeballed the location for a mounting hole. Turns out I am blinder that I thought as rear of the fender hits the lower door hinge and worse the front of the hood didn't come close to matching the top of the grill.
So I spent some time today fixing that.
Pic 1. Borrowed some of my wifes baking paper and lined it up on the cowl using the seam that runs under the A pillar and the cowl door opening edge.
Pic 2 and 3. Held the fender up to where it should be and traced the fender contour with a fine markie. Notice the correct gap from the door hinge.
Pic 4. Took the template over and taped it to the PS cowl using the same orientation points but with the marked side facing in. Notice how the marking from the other side shows thru.[cl
Now I will have a better idea where to make the final mounting holes as well as being reasonably sure that the fenders are located in the same place on both sides.
Pic 5. Show the fenders once again just sitting loosely.
The plan is to fully mount the fenders tomorrow and then turn my attention back to the hood. I want to be able to have the welding and grinding done on the cab and front clip by the end of the month so I can pull them off and start cleaning and painting the frame. If the weather ever warms up.[S
Thanks for visiting.......
Torchie.
