35 IH AKA Project "Riff Raff" build
Changed the headers from what I had posted before.... (I know... the collector is crooked.... it's not welded on yet...)
Headers welded up and painted, floor structure almost done, rear kickup started, started fitting the box.
Looking good PP. Not sure about that pinion angle though::p
Didn't I tell you.... I am going to mount the engine vertical and just run a belt between the tailshaft of the tranny and the rear axle. Wallahh..... no more hump in the floor :D
Ditched the split lip design "widow maker" rims, found a pair of 16.5 steelies at a local junkyard with like new tires already mounted for cheep. Wire brushed them and painted them with tractor paint. This will save me some $$$ over my previous plan of wide wheels / tires. Some work done on the trans hump and started the floorpans. I also attached the stake holders to the shortened bed. I have them bolted on but plan on riveting them on later.
Last but not least.... I am stuck with a decision on how to construct the rear suspension. I intended to have a 4 link but I want my axle further forward than I originally thought which will make the arms very short (in my opinion). I am worried there will not allow for the axle to move properly. To better explain I am worried if I jack up one of the rear wheels that the other would come right up with it (I believe it is called articulation?). I have been considering running ladder bars with them angled in towards the trans tailshaft to allow the axle to twist/rotate. By looking at my rear kickup does anyone think a 4 link will still work ok?
I figured out what I am doing with the rear suspension. I am changing my plan to a triangulated 4 link. I have a set of coil springs laying around that I can use unless I run across a cheep set of coilovers. Since I can't weld to the cast pumpkin I am going to run a hoop over the pumpkin to allow me to run the short angular bars on top as close to the center of the axle as possible. Through some reading I have learned that the S10 crowd uses this trick quite often. I ordered a kit, should start installing within the next 2 or 3 weeks.
The triangulated 4 link is in. Now I need some coilovers since half the mounts needed are already there now.
Thanks for the compliments. I do plan on installing gusset plates & reinforcements where they are needed. I just wanted to get the basic layout done. I am just to darn impatient to see what it will look like I guess.
I like it so far.
Your link geometry looks to be a bit off though. It may just be thge pictures, but your instant center appears to be behind the axle.
It is behind the axle somewhat as I didn't want to shorten the upper arms.... is there a huge problem with doing this this way?
Your instant center should be in front fo the axle. The biggest thing you will notice is a lot of squat, and the axle will hop pretty bad if you try to do a burnout, or slam on the brakes.
Hmmm.... that kind of sux then. At this point I am not going to mess with it. If it hampers my burnout ability I will have to take action. I guess I can shorten up the arms and move the hoop to center later on if I have to.
Thanks for letting me know
