61 Volkswagen V8 Single Cab Street Rod
Gas Pedal is connected!
http://www.BenModified.com
Very clean build! The conduit certainly cleans up the wiring... I used to run all the wiring on oilfield truck beds I built through conduit...keeps wires from being ripped loose out in the boonies. :)
Finished up the inner fenders
Working on completing the front sides of the fenders
Cutting up and using another trailer fender
Used the planishing hammer to round off the cut edge to match the rest of the fender
Going to use some metal mesh to make some compartments in the corners of the bed which will be covered by the bed sides.
Little late, but I like the cradle idea...
I have been itching to do a mid engine VW bus for some time now, and this idea makes my thoughts a bit more feasible.
Going to bookmark this one in my brain for the future
The passenger side is done!
Pocket behind the right rear wheel
Welded on some Dzus fasteners for a removable cover over the charcoal canister behind the left rear wheel.
Took the measurements for an Aluminum Treadplate bed floor. Going to the big city soon to pick it up. They have a huge shear so I can get the size I want and nice smooth lines.
http://www.facebook.com/BenModified
Installing 1/4" aluminum floor in the bed
Playing around with some ideas for headlights. These chrome bullets are set up to reverse from "Dagmars" to lights. Using a spring loaded mount to quickly rotate them and lock into position.
Sprayed the frame rails under the bed floor with some aerosol bed liner. Also drilled and tapped all the bed floor mounting points and bought some nylon washers to place between the bed floor and frame rails to allow air floor and prevent moisture accumulation.
Also finished up the other headlight mount
And started making up the under the cab lower rails.
Good test drive [cl
Thought it was classic to see a cop at 3.23 minutes into the drive [ddd
Sounds good :cool: Did I hear a little stumble when you start to throttle up from a stop?
Good test drive [cl
Stumble, yes...need to adjust the accelerator pump. Funny how many people have noticed the Highway Patrol car!
