StoneCold65
Nice exhaust outlet on the '56...that should keep the moisture away from the cab corners.
I'm interested in the Afco shocks you were given for the '53... what's the inside diameter of the mount ends?
Thanks...
I was wondering if anyone has seen or tried using the fresh air vent in the cowl as a air scoop for the engine? I would greatly appreciate any photos or info you might Have. Sorry I have not posted in a while due to working on other projects but this truck is always on my mind. I plan to update soon. I have been polishing on an old set of ET slot mags I traded for. I figure they will look much better than the outlaw II wheels that are currently shown. Also I took the plugs out of the 455 and turned it over some last night. It turns real nice for motor that has set for a spell. Think I'll slap some valve seals in it and Cover gaskets along some fresh paint. Viola rattle can rebuild!
So Mr ChevyII when are you going to start the new rat truck build thread?
