Bonehead is back to work
Making some moves again. Roof off pics
Looking really good , i love the veiw you have going on at you place man i would die for that and the roadster pu in the first pic is priceless , should fly with that power plant [P can't wait for more
Hillbillie
Thanks, guys.
I started putting in the engine.
First, I blocked up the engine and used my trusty angle finder to set the engine tilted up in the front, between 3-5 degrees. This will help my rear driveshaft angle, and should fit up to my rear pinion angle which is down 3 degrees.
Locating the engine on the chassis, is a matter of rolling the frame forward or back to make adjustments. I marked where my firewall will sit on the frame, and put the engine slightly ahead of the fire wall. In my case, 1 inch worked well.
Are you going to have enough room between the motor and front axle to wedge in a radiator? Might have to place it in back. [ddd
I have been around. (At the swap meet the other day I guy asked if I could put a NHRA legal bar in his 9 second car. I told him the first one I did was a Mustang back in 1983.)
Anyway, hope you guys are ready for some more pictures. I stayed on this truck all weekend.
1st is the almost finished motor mounts. All the grade 5 hardware will be replaced grade 8.
