kenny c
Be safe
Be safe
I think it will twist and buckle before it flattens.
I like it the way it is. Make the pan match and walk away.
I am wondering if it is the same thought that is bouncing around in my head...Lol. My concern isn’t the pan it’s how close the ends are to the rear fenders, Doc.
I agree with you that there could be twists and such given that this isn’t a 40’s type flat face only bumper. This a a heavy u channel shape.
I have another option that I will post up later.
Check the link below and see, Skip.I am wondering if it is the same thought that is bouncing around in my head...
If you stretch the upper and lower lip, it will not buckle or twist. I`m sure you can get it to fit nice and tight that way, but it will destroy the chrome. Using a press will probably destroy the chrome too...and the bumper.
Here’s a wild idea........change the body notch to fit the bumper. What’s a little more cutting and welding, eh? That way, the chrome bumper stays virgin. Extend or make a new gravel pan to fit.[P[P[P[/
Thanks Bama. Not wild at all . That will most likely happen wether I Use the bumper as is or de arch it . The wrap around ends on it are quite long which is why I used two 49 Plymouth front bumpers on the truck. In this case though I like the long wrap around.
I am considering not only moving the bumper inset on the fender but making them a bit more pronounced as well . Giving it a bit more of a custom look. I want it tucked in as close as I can get it.
At this point it’s still all imagineering as MAC likes to call it.
Thanks for all the response’s everyone.
This is what I was thinking. I see Torchie is onto it and then some. I kin'a' like Doc's suggestion, too. Pretty sneaky.Here’s a wild idea........change the body notch to fit the bumper. What’s a little more cutting and welding, eh? That way, the chrome bumper stays virgin. Extend or make a new gravel pan to fit.[P[P[P
That is a really sharp looking bumper and the plan sounds solid., not sure if I missed it it do you have matching one for the front?
Wow that really sucks Torchie
Oh well. All is not lost. I'm sure there are parts you can use. May be time to start looking for a more modern donor frame again.[P[P[P
Sorry to hear about your luck Torchie. I'm sure you'll come up with a plan though.
