HELP!!!!!
abnscout5w
Sep 30, 2011
8
I have a question about frenched headlights for a 1949 Chevy truck. Is there any way to the frenched headlights without paying $250.00 or more for a kit? I am starting a 49 Chevy truck rod and was looking at doing this but did not know it would be so much.
What kits are you looking at? Why would you need to buy a kit anyway, what's all included? Get some lights, cut some steel, weld it in.
This is from Ask.com
My Full Custom – Frenched Headlights
I’m trying to keep a late 40s – early 50s feel to this car. I studied some early custom cars built by George Barris and Harry Westergard and decided that frenching the stock headlight rings would give me the “bullet look” I wanted. Naturally, it didn’t work out that way.
To “French” something on a car is to recess it into the body to give the car a smoother, sleeker look. With headlights, that usually means that you need to put them in to the fender from the backside.
Rather than flip and re-use the the old clutch head screws and old clips, I thought I’d just weld some bolts to the bucket so I could remove the buckets easier (fewer screws). The first thing to do was to drill some holes through the buckets and the fenders so the holes would line up when I flipped the buckets. NOTE: If I had it to do over, I’d just drill out 4 of the stock holes and re-use them. I had a few clearance issues with the holes I made. Plus, I’d have less holes that way. I don’t think I took any photos of this step. Do this with the buckets in the car so everything lines up later when you take it all apart.
Next, I shaved off the lip of the headlight buckets so they’d seat right up against the fender and hammered down any high spots. My long-time hetero project partner Kevin (a.k.a. MercMan1951) was good enough to help me out once again. We cleaned up the area around the fender opening in preparation for welding. To get in the little nooks and crannies, Kevin showed me a bodywork-ninja secret: the sanding star. You take a normal Roloc sanding disc and cut “V” notches around the perimeter until it looks like a star with a dozen or so points. It’s great in the crannies, and the deadly art of the assassin.
At this point we hit a snag. We started roughing up the stock trim ring (which I thought was supposed to be stainless steel ?) and it was brass or something. The “chrome” sanded off and it was a gold colored metal underneath. When I tried to tack it to the car, it wouldn’t weld either. SO, NOW WHAT?
Kevin has a 51 Merc and he is going to use a Winfield style headlight treatment, so he offered up his stock 51 bezels. We held up the Winfield ones on for kicks too. But in the end the 51 Merc bezels looked good, and at $0 they sure fit the budget. We used duck tape to approximate the final shape and hit it with spray paint to get an idea of what it might look like. The Merc bezels also tunneled the headlights a good 3/4″. I played around with tilting the top out to get just the right profile, too.
In the end, I felt like the Merc bezel was just a little too long, which caused it to disrupt the curve of the fender. Plus it was a little more tunneled than I wanted it to be which also created a gap between the headlight and the inner end of the bezel. I decided to shave 3/8″ off of the end of them. I took a combination square and a sharpie and drew a line around the base and then took a cutoff wheel and trimmed off the excess. I taped them up and liked how they looked. There is still a “dented in” area where they meet, but that will be filled with “glamour putty.”
So now I was ready to weld the rings on. There were a couple dents on the Merc bezels, so I dinged those out. I sanded through the chrome and the copper down to bare shiny steel (can’t weld to chrome or copper). I had to cut out and make patches for the screw holes in the bottom of the bezels as well. I bolted the buckets in and shimmed the bezels on with cardboard to make sure I had an even gap all the way around. NOTE: Really, bolt them in solid. At first I didn’t have them bolted in, and things were off. Then, when I went to adjust the bucket, it fell out and I broke the @#$%^ headlight!
Next I tacked the bezels up and pulled the cardboard out to make damn sure it was perfect before I started welding them in for good. I wound up adjusting one of the bezels. Then, when everything was perfect, I went around and “sticth welded” the whole assembly together. A “stitch weld” is where you tack, move, tack, move, tack, move… it is a painstaking process but it keeps heat from building up on thin sheetmetal and causing warping. About a million tacks later, it was starting to look pretty good!
Tags: 1950 Chevy Fleetline, Detroit Poor Boys, Frenched Headlights, Marc Nischan
[P
[P
Might like this
Customs Volume 1
Shaved trim, rounded hood corners, frenched lights, 53 grille opening with Corvette ... Retention of some of the Pontiac specific trim makes the car stand out from ... Somewhere around 1965 it got the top cut off for a bubbletop conversion that ... The top is chopped, it's sectioned and the rear fenders have been lengthened. ...
www.donshotrodpage.net/Editorials/ModCustomsV01.html [cl
Pour man french head lights. It easy on that truck
Unbolt the bucket and remove the spring nuts or nuts from the mounting surface. Move the buckets to the inside of the fender.
You will need to figure out how far back you want the head lights and make spacer to go between the fender and head light bucket. Bolt every thing together with long bolts ( I went to home depot and got the nylon spacer they sell in the nut and bolt section of the store)
You will need the hardware that holds the head light ring in place and remount them to the mounting flange.
Mount the head light ring then measure the distanced from the inside of the head light ring to a little past the ring that hold the head light in place.
cut a peace of metal that wide and form it around the inside of the head light ring and welding the ends together or rivet it. fasten it to the inside of the head light ring and mount the ring to the fender. You may need to do some grinding to the open in the fender to make it fit.
That the way I did my 58 rambler
Here the best pictures of before and after
