ratrodfireman
Here's pictures of my Outlaw Fire build.It started with a 97 Isuzu rollback chassis and a 1950 Chevy truck.stripped the frame completely and cut it in to at the rear springs.I then turned the remaining frame completely over and cut it into at front and narrowed it 4 inches.This allowed me to raise the spring mounts in the front upabove the frame so that the frame was lower to the ground.I moved the springs forward giving it the stretched look.The motor mounts were moved up on top of the frame.The cab was channeled 3.5 inches.The rear sides are actual hose dividers out of a fire truck. I added the 7 inch stacks.After all of it was put together I airbrushed the color and rust color. I had a local painter to letter the door.Later on in the day when he lettered the truck I used a piece of cardbord to sand the doors and letters to give them the old patina look.Currently I'm building a Outlaw Sheriff Paddywagon.You can visit my thread in the builds forum Chopped Fatfendered Chevy. Later Dean
