New Guy with a 47 Dodge
Will do as soon as I get the old Dodge home… :roll eyes:
Right now I am in the progress of getting my 65 project rolling toward re-assy… Had a bent frame issue, so today I am visiting a fellow Truck Forum member to pick up a straight frame…[cl
Will Post here when I start the thread here...:D
Did you get that frame???[S
Are you going to post a thread for the 65 you are working on?[S
reply
I did get the frame, it's a GMC so there are leaf springs out back vs trailing arms and coils… Plan is to get the frame partially dis-assembled… i.e. remove front crossmember to replace with 85 front crossmember that is currently installed in the bent frame, then flip either the existing rear-end or swap the original rear end from the bent frame… those axles are already redone as 5 lugs… gotta also clean and prep for paint…
Build thread for the 65 is linked in my signature line…
Diggin the '50 and the '64...[P
